How to use "Accessory Mode" on your Spyder RT
finless
Finless Video Tip of the week! :)
How to use "Accessory Mode" on your Spyder RT.
I had done a old video about this but it was not very clear and still got a lot of questions so I re-shot the video this morning. I hope this is clearer :)
Accessory mode allows you to run the radio without having all the riding lights on thus running down your battery quickly. I use this a lot while working on the Spyder and can run the radio for HOURS!
Also I did not show this in the video but if it does run your battery low, it will shut off Accessory Mode automatically and it does this before your battery gets too low to be able start the motor.
Enjoy,
Bob
Thanks for posting the video. Curious how this was discovered. I didn't read anything about this in the owners manual.
Believe it or not, I discovered it myself early on with my Spyder while messing around with the dash gauges.
Bob
I found this under Audio Controls in the owners manual when I read it...I know, first mistake reading the instructions. Similar to what Bob posted. We use it often.
PK
Audio System Power
Follow one of the following steps below to turn the audio system ON:
– Turn ignition switch to ON
– Press MODE button for 3 seconds immediately after ignition switch is turned OFF.
Follow one of the following steps below to turn the audio system OFF:
– Turn ignition switch to OFF
– If the audio was ON with the ignition switch to OFF, press MODE button for 10 seconds.
PK
Audio System Power
Shame Shame Shame:lecturef_smilie::lecturef_smilie::lecturef_smilie:
Now you broke the code
Men don't read Maps or instructions:roflblack:
Sorry...
I give Finless huge props for finding it on his own...When we got the Spyder, Wifey wanted music, so I needed to sort out the preselects and had to use the owners manual to do that.
Finless has posted some of the best assets on Spydelovers.
PK
Sorry...
PK
Thank you!
I appreciate the kudos...
I absolutely love teaching no matter what it is that I am doing. Good or bad, right or wrong on how I do it, I show what I can.
Thanks! :cheers:
Bob
PK
Audio System Power
I read this last year but never could get it to work. I think the time needed to hold the mode button may be more than 3 seconds. Either that or I did something else wrong. All I know is I tried it several times with no luck. But it worked today when I tried it.
One caution though! If the parking brake is NOT set, the warning beep does NOT stop after 20 seconds like it usually does. So you cannot leave the parking brake off AND listen to the radio with the key off, unless you want to hear the beep stay on the whole time!
FWIW, I turn off key, and within a few seconds, maybe 10 max but I never timed it, I hit mode and hold it until the display fires up. Then adjust radio as desired.
As for the parking brake, I will need to check this to see if accessory mode still keeps it beeping. Either it does not, or each time I tried the accessory setting the brakes were set.
PK
The 2011 RTS SM5 doesn't have this warning. The only warning it gives me is if I try to start rolling when the parking brake is set. I get a beeping letting me know I am letting out the clutch and the brake is still set.
As I recall they added the "not set" warning in 2013?
Bob
Bob
Parking brake not set warning is on SE models because they can roll away even in gear. My 2009 SE5 had the same warning.
Enjoy,
Bob
Hi Bob;Thank you for all of your informative videos. My Wifes 2010 RTS acc mode won't stay on. As per your instructions, after turning the key off , pressing Mode and getting Limp home , park lights ?(LEDS),fender markers and tail lights go off as they are supposed to do but the fuel and temp guage lights stay on (and radio)-then in 5-10 seconds- I get the Check engine light for 1 second and everything shuts down. What are your thoughts about this ? Thx Jae
That is odd but I cannot speak for the 2010. Maybe it wont work on a 2010? Someone with a 2010 needs to chime in.
But with that said maybe your battery is not holding voltage well?
The Spyder will shut off the ACC mode when the battery falls to a certain voltage. This voltage is not low enough to keep you from starting your spyder which is a good thing it does that.
It might be possible your battery while still capable of starting your Spyder and charging, it rapidly drops to that threshold voltage when under load and not running. I just replaced my battery for this reason! My battery still worked e.g. started the spyder, etc but when I would stop say to fill the tank for few minutes leaving the key on, the battery voltage got real low FAST! One time I left the key on for about 5 minutes and almost could not start the Spyder. It barely turned over. Yet again, when recharged by running the motor, if I turned the key off right away I could leave it in the garage for days and it would still start.
So the point is, under load with no motor running a battery that is starting to go just wont deliver the AMPs for very long before draining quickly. I hope that makes a little sense?
If you have not replaced your battery on your 2010 yet, it might be time. My 2011 just got replaced a few weeks ago.
Just a suggestion as to what might be happening? Only way to know if this is the reason is to use a volt meter and see what the voltage is without the motor running. If it is dropping below about 12V with the key on or in ACC mode, you got a battery going on you.
Bob
Bob
Hi Bob; The battery is 1 yr old and after being on battery tender over night - shows 13 volts. With key ON and computer all booted up and radio ON (5-10 minutes)- voltage dropped slowly to 12.36 volts and held there . Tried Acc Mode trick again with the same results. Key OFF and the battery returned to 12.86 volts. I call the battery GOOD. I started the engine to see the voltage drop during cranking - 10.94 volts. Engine running - charging at 14.1 volts. Key OFF - battery slowly returned to 12.83 volts. Acc Mode is not a priority as I would probably seldom use it. Your video perked my interest - so I had to try ! Any more thoughts ? Thx and keep the videos coming. Jae.
