How to Turn Traction Control Off For Dyno'ing. Anyone?
  • Thread starter Thread starter MetroAsian
  • Start date Start date
M
MetroAsian
Guest
Does anyone out there no what wires to pull to disable the Traction Control System. I'm not entirely sure if the spyder will perform okay on the dyno with it off. I guess I will find out in a few hours. Also, where is the o2 sensor located on the Spyder?
The o2 sensor is in the tail. I think you can reach it from under the passenger section of the seat. You may need to remove the bottom panel though.
I would think that you'd only need to remove the two sensors on the rear wheel as the fronts wheels won't be moving anyways, right? It looks like the rear ones are removed by unscrewing two screws on the mounting plate that they are attached to.
If the front wheels are not moving you are right. :thumbup:
MM
Actually, the O2 sensor itself screws into the 2-1 exhaust collector under the bike. You can't miss it... it's the only thing in the exhaust system with electrical wiring.
It's connection is in the tail... behind the battery... and like you said, remove the tail section bottom panel (7 Torx screws) to access it.
