bruiser
Your dealer has ripped you off. Had the wife's bike in on March 26, 2013 for a service prior to a trip. The dealer noted on the repair that they changed the plugs, adjusted the belt, changed oil and filter and checked battery and charging system. Bike was ok. Last week after I changed the clutch fluid wife took the bike out for a short run. She was gone less than 2 minutes when she came back and said something wasn't right. The bike was shaking and vibrating. I checked it over and decided that it was down a cylinder. Ordered plugs and wires from Ron.
Today, changed plugs and wires. Rear plug, as most of you know is easy. Plug wire came off fairly easy, took some effort, but not too bad. Plug came out ok but I noticed some "drag" on the threads as it was coming out. Having turned wrenches on anything from vacuum cleaners to jet fighters for the past 44 years, you come to understand what I mean when I say dry threads. Anyway, first thing I notice is there's no heat sink paste on the threads. I see that the plug is a DCPR8E. Ok, that's the plug BRP went to in 2011 for the RT. Plug doesn't look to bad since it's only been in around 7,000 miles, firing tip not to worn. Top tip is still shiny.
On to the dreaded front plug. Air box comes off after about twenty minutes work. Biggest thing is cutting all the zip ties. The front plug cable is a b**ch. Pulling, prying, cussing, using all manner of tool, it ain't coming off. I have to cut the boot to get it off. Clean the hole with compressed air, important step, Plug won't budge. Break out the big boy tools, 1/2 drive with an extended ratchet handle. Plug breaks loose. Out it comes, hmmmm, no drag on the threads. Plug is out.
Wait, what's this? The plug has heat sink paste on the threads. Hey, what the he** is this? This plug is a DCPR9E. That is the original factory plug! The firing tip is worn. The last three threads are soot covered. The top tip is dark gray from heat.
I was ripped off.
Ok, anyway, the bike runs a lot better.
What's the takeaway? Well, I haven't used this dealer for awhile anyway. And I'm damn sure not going back now.
I was ripped off.
