F3 gas cap closing
by Rattlebars:
1. Like the starting procedure, the gas cap closing has a specific sequence. After fueling, flop the cap back down into the hole. Turn the key clockwise to 3 o'clock until the cap drops almost all the way down. Turn the key anti-clockwise as far as it will go to 1 o'clock . Press down on the edges until it clicks. Turn the key anti-clockwise the rest of the way to noon then pull it out. Ready to roll.
. I use this method and find it works well after I filed the lock tabs on the cap.
Additional ideas:
2. A bit of oil in the mechanism and Vaseline on the rubber also made a difference.
3. I took the locking lid apart and filed the sliding contact parts to reduce the locking tab thickness.
4. There was also a post that recommended making shim washers from the metal in a pop can. The washers are placed under the bolts that hold the gas cap lid in place.
Good Luck..
