Here is my first rear tire I figure it is ready for a change others have said it has some life left.
What say you. It has 8700 miles on it.
I don't know what you have done to wear it out so fast, but I have over 16,000 on my original Kenda and it looks better than that.
......You have been running your tire pressure too low. Thats why you have more wear in the middle....... When you turn with low pressure the side some what collapses on the outside (centripetal) side and all the wear tends to be in the center.
......With more (30#) of inflation I would say you have more mileage left. IMHO
Sorry, but you've got that backwards, Jack - going too HIGH with your tire pressure (especially on the rear that doesn't get much torsional wear from steering) generally wears the tread more in the centre because the tire 'balloons' as it spins & it does that even more as it heats up thru use!!
If you go too LOW with your pressures then the centre of the tread deforms up & barely touches the road, wearing the outside more than the centre!!
Just about any 'tire wear guide' or handbook on this sort of stuff can confirm this if you are interested. :thumbup:
That said, it does look like it's getting to be time to change that tire, Buggy.![]()
I guess you've missed all the discussions the past couple of years about the rear tire wear!You only have 8,700 miles on that tire? :yikes:
I guess you've missed all the discussions the past couple of years about the rear tire wear!What SpyderAnn01 says. Your tire is wearing on par with a lot of the car tires many of us have put on. I don't think I've seen any comments here about mileage of the late 2014 and later Kendas. Your experience is encouraging.
?.... Anyway this has worked well in over 65 years and one million plus miles of riding for me. Everyone should use their own judgement when it comes to tires and oil. Asking those question here only brings out strong opinions and disagreements....
