How long will a Zumo XT run on its own battery?
If use your battery for the power source you shouldn't have to remove any tupper ware .... just make sure the HOT wire is fused ..... Mike :thumbup:
The XT actually requires no fuse due t its wiring harness, Mike :thumbup: . If it is relatively easy to get to the battery on an RT, the installation is a breeze. The is only one + and one - wire, unlike previous Garmin models. Took me all of 15 minutes to install it on the F3, including taking off one side panel for easier access.
Pete
If you wire direct to battery, the cradle power will always be on. The 21 RT has a switched 12v easily accessed on the right side.
Have only gone 2 1/2 hrs on mine. Did not check remaining battery level before I topped it off. Normally it's in the mount so it stays charged. Happened to use it in the car and don't have a mount there.
