Rookiespyder
Hello, how hard is it to do an oil change on a 2015 RT Limited 1330 ? I just bought the Spyder in the middle of July last summer from dealership. So now it is do. Dealership cost to much so I might tackle it myself.
It's not difficult at all. You will need a torque wrench that goes down to 18 ft-lb and a 36mm socket for the engine oil filter, a T-45 drive socket for the engine drain plug and a 6mm hex drive socket for the transmission clutch housing drain plug. You will need to get the bike off the ground (level) high enough to get at the plugs and slide a drain pan under there; 8-12" should do it.Hello, how hard is it to do an oil change on a 2015 RT Limited 1330 ? I just bought the Spyder in the middle of July last summer from dealership. So now it is do. Dealership cost to much so I might tackle it myself.
EASY AS PIE.......
however, b4 u do the oil change, order yourself a set of GOLD PLUGS for the 1330.... like a lot of us, you may just strip-out the OEM plugs, and will have a difficult time with them....
give Tim a call at: 888-578-3851
and here's their website: https://goldplug.com
say HI to Tim for me.....
Dan P
SPYD3R
Easley, SC
Thanks for the reply. I think that I am going to give it a try. I can get the oil change kit from the dealer. I am just not exactly sure what panels have to come off. I guess I will have to watch videos on it.It's not difficult at all. You will need a torque wrench that goes down to 18 ft-lb and a 36mm socket for the engine oil filter, a T-45 drive socket for the engine drain plug and a 6mm hex drive socket for the transmission clutch housing drain plug. You will need to get the bike off the ground (level) high enough to get at the plugs and slide a drain pan under there; 8-12" should do it.
Then, 5-1/2 quarts of the right oil and an O-ring and crush washer set, plus the oil filter. You can buy the oil, filter and washer kits from BajaRon and Lamonster with everything you need. Saves a LOT of money for labor at the dealer.
View attachment 158468 View attachment 158469 View attachment 158470
Not necessary. Just use the right tools and you'll be fine.
I'm guessing you haven't looked at my pictures. Just did both my RTs. Do it right and it's no problem.i did.... TRASH....i'm guessing you've never performed your own oil change.... just say'n....Dan P SPYD3R
Watch the videos. Read the various threads on this forum. Get the right parts and tools. Then, just tackle it. You'll be surprised how simple it is really.Thanks for the reply. I think that I am going to give it a try. I can get the oil change kit from the dealer. I am just not exactly sure what panels have to come off. I guess I will have to watch videos on it.
Apparently Gold Plug has folded, the phone is disconnected and e-mails etc... go unanswered. Placed an order and funds were paid...crickets
