gkamer
Sadly passed away, December '23.
How do you handle different tire pressures?
I recently purchased a portable tire inflator to handle the task of adding air, when needed, to my tires. In addition to that I also purchased a JACO digital tire pressure gauge to check the tire pressure of my tires. But, as if that wasn’t enough, I also purchased and installed the FOBO 2 TPMS to monitor my tire pressure in real time. The problem is each of these devices tend to show three different pressure readings for the tires. There is usually not more then a 2-4psi difference in each devices readings. So the question is which one to believe?
In reading reviews of the various devices I believed the JACO gauge was the gold standard for these devices. Likewise the tire inflator also got excellent reviews. My thought was to use the inflator to over inflate the tires a little, and then use the JACO to deflate them back down to the recommended psi rating. But I’m sure if I do that, then when I screw the FOBO’s back on they are going to display a psi different from that the JACO showed. This is giving me a headache. Your thoughts please….
