How do I run a USB cable from the glove box to the frunk?
Stache
I’ve mounted a dual USB and 12v port in the frunk, direct to battery (fused). I want to run a charging cable from there into the glove box.
I’m not using the BRP-C port because a. it’s switched and I want always on, and b. no matter which cable I connect to the BRP-C port the charging flickers on and off.
It's not too difficult. Remove a side panel to gain access to the underside of the dash panel / glove box area. Cut holes in the glove box and frunk aft wall (or a notch in the ridge of the frunk, under the gasket) to run your wire. Thread it through the cavity behind / under the headlight. Use rubber jacketed 2-conductor wire ideally to avoid chafing of the wires.
