How do I replace 2020 RTL rear trunk lid shock/lift cylinder? Lid won't stay up!
drkennedy61
How do you replace the trunk lid lift cylinder? I put a luggage rack and it will not stay up. I have heard you can install a spring on them to help make them stronger. I need some information on how to remove it. Thanks
Honestly, I sort of looked at my repair manual and didn't see any info on this.
Looking from inside the trunk there are two torx screws, have you tried removing these to see if the passenger back rest would come off? If so then there would be something holding the top plastic piece on that would need removing to give you access to it.
I would start there. Looking in from the rear, the strut is located on the right side, and you can barely see it in there.
I can see how anything at all will cause it to not stay up. Did you by any chance add the luggage rack?
McMaster Carr will have something that will work, you just have to look for it. Some people have said that they have gotten the seat struts from auto parts store so that's another source. No way would I put another OEM one on there as it is just too weak.
Thanks for sending me the two files to get my 3D piece for the trunk lid at makexyz in tempe AZ. It's an internet company that did the piece for $14.90 including shipping to me. It works great and takes 2 minutes to install.
I am so gonna steal that idea. Thank you.......................:cheers:
Hi, another member - " safecracker " had the same or similar item .... He sent me a tracing of the one He bought .... I copied it onto a piece of TREX plastic wood ..... I did a bit of trimming and it works better now .... I offered to send anyone here a copy of mine ..... just send me a STAMP and your address and I'll send you a copy , and you can make your own ..... Mike :thumbup:
You are very welcome Dave. My pleasure !
