How do I put my RT Ltd into Neutral and shut off parking brake alarm?
I always recommend leaving it in Neutral .... I don't do it this way .... The SE trans. allows you to move the Spyder around without being it neutral ....Mike :thumbup:
Yeah, I know but just like the ease of having it in neutral.
OP, you can "mute" the sound by at least half if you take the IC off, remove the back cover and apply some tape to the emitter. With the back cover off, reconnect the cable and turn the key on/then off to locate the emitter. I have had my F3S this way for years. I did two or three layers of a metalized tape and it has held up perfectly...
EDIT: I just tuned in to the fact you have an RT, but I "think" the premise is the same...
