How do I go to a higher speed on Cruise control?
Mike0123
Hi all. Have a question that I can’t find a direct answer to. While out on our '21 RTL with cruise engaged at 40 (for example), I throttle up to 50 and I want to set the cruise at this new speed. I’ve tried pushing down, and that doesn’t seem to work (it falls back to the previously set speed), up just increases the set speed 1 mph since it’s already engaged, BUT sometimes, something I’m doing works. Sometimes the cruise will stay at the new speed.
So, am I just pushing up enough times to raise the setting, or is there some combination of pushes that is resetting the cruise to the new speed? The only reliable thing I can do every time is switch it off then on, then set the new speed.
Anyway, as they say… first world problems.
Push up and HOLD until the new speed takes. Push up and let go moves it up in 1KPH increments, down drops it by 1KPH per push. You get a sense of the time to hold it up to set the new speed, occasionally I'll over shoot and have to knock it back a couple. Least that's how mine works.
Yeah I forgot to mention I did know about that, but I was hoping for a quick twiddle that simply set it again to where you are. I’m sure you have the answer. Thank you.
Tap the brake pedal or shift gears, then you can set it to a new speed by pushing down and resume the previous speed by pushing up. Or switch CC off and back on.
This is what prompted my question. I may simply need to pay more attention, but it seems when I downshift, or tap the brakes, then accelerate to a higher speed, pushing down seems to just “turn on” the previous, lower, setpoint.
It’s certainly not a big deal, but it did prompt that question.
I wonder if they reversed how resume/set works on 2020+ trikes.
I just went out and checked mine and it is indeed labeled as @Snoking1127 described it working, but I swear it doesn't work that way... but you have me doubting my self now. I'm going to have to go for a ride to check.
