Hopefully a different sway bar question
vindex1963
I had adjusted the front shock preload all the way up to help with cornering, tonight I installed a BajaRon sway bar and was wondering if I should back the preload down or leave it the same. I rode around some tonight and it felt more stable but tomorrow my wife and I are going on an all day ride, her on the Spyder and me on my Strom, she knows the Spyder way better than I do (it's hers after all).
So max preload or put it back to factory?
I suggest in my instructions (at the very end) it is a good idea to back off the shock spring pre-load adjustment after installing the sway bar upgrade. Especially if you have set the pre-load up to reduce lean in turns.
Though you may want to keep the pre-load above the factory setting (which is very low). You will probably be much happier with an initial setting of something just above the factory setting. Experimenting from there is a good idea as well. But it is a good place to start. It is unlikely that you will ever want to return to the max pre-load setting with the BajaRon sway bar installed.
Hope you love the bar! :thumbup:
If I remember right the factory preload was notch 3 I have it at 5 so I'll back it off to 4.
Thanks for the response.
Preload?
Is there a "how to" video on adjusting the preload? :helpsmilie:
Went through the instructions and can't find that, doesn't matter really I backed them off one notch.
She LOVES the bar!!! See the above assessment.
