IdahoMtnSpyder
Just for grins and giggles here are a few questions I've thought up related to tire pressure.
What is the best trade off between ease of turning by running higher pressure, and tire traction with wheels turned all the way right or left? And how does forward speed factor in?
What is the effect on wear from average speed? Will a Spyder driven at an average of 40 mph get the same, or maybe 1 1/2 times greater, tread life as one driven at an average of 70 mph?
What is the effect of road surface? How much more tread life will you get if you drive only on smooth concrete freeways versus always driving on fresh chip sealed roads?
How much does driving around curves vs. straight roads affect tread life? See this comment: http://www.spyderlovers.com/forums/...-Opservation&p=1387820&viewfull=1#post1387820
The charts in the document linked to here, http://www.spyderlovers.com/forums/...-Opservation&p=1387903&viewfull=1#post1387903, show a somewhat straight line relationship between load and tire pressure. But does the straight line hold at loads less than what are shown on the chart, which is the case for Spyders, or does it curve? If it curves, then which way, up or down?
For a given Spyder weight does a larger patch contact area with a lower coefficient of friction provide more traction than a smaller contact patch with a higher coefficient of friction?
How does the stiffness of the tread and sidewall affect what pressure gives the smoothest ride? What is the effect on tread wear, both overall and across the tire?
Real reliable answers to most of these can only be derived by systematic controlled testing. Testing that would involve at a minimum dozens of vehicles and dozens of tires at almost innumerable variations of load and tire pressure. The value of the answers won't come close to the cost of obtaining them. Hence, we are stuck with relying on dozens of individual experiences, experiences that vary widely, to come to our own individual conclusions.
