Sarge707
1- I found Braking Most Comfortable if I keep My heel on the metal Bar So I could just swivel my foot over from the peg to brake! I found keeping my WHOLE foot on the peg was Not Good because you had to lift your whole foot up to reposition to the brake losing valuable time?
I had two attractive car wash Mop handles and Zip tied the first one with 3 tip ties and then added the second handle over it and secured with 2 Zip ties.
It added about 1/2 inch to the height of the bar and is a Lot more comfortable and secure to rest the heel of my foot on and Much easier to swivel the ball of my foot over to brake with.
If doing blind corner Back Woods twisties I can even keep my foot right over the brake on the blind corners and then swivel it out to the peg when things happen Less fast.
2. I bought a Slime 400Psi Tire "Topper offer " $9 to Maintain and adjust tire pressure and Used the Blue Gauge Posi-Locks to put the same connection as my Battery Maintainer on it so the same connection maintains my battery and tires. Its F3 Size!!!!
3. The yellow Brake fluid Container has Been "Washed to the Extreme!" and Now contains 6-7 ounces of oil instead of carrying a quart container.
