HMF exhaust and optimizer
Justin_m_3
I have a 2011 Can-Am Spyder RS-S. I bought the hmf exhaust and optimizer. After installing both the bike is running way to rich ....bogging....black smoke. I checked and all the modes are set right and the idle mode is at lowest setting. Will barely run its so rich right now. Ideas?
I did notice two vacuum lines weren't connceted around the map sensor area. I also removed the map sensor for the optimizer install. Does the map sensor get installed any certain way? I don't believe so. Thinking about taking optimizer off and just running exhaust.
