Up to 500° but note their warning at the bottom of the pic.
I haven't shot the temp on that part of the pipe yet but I'll bet it's below 500 degrees. I'll shoot as soon as my gaskets get here. I just bought a used Hindle too so I can get a true reading on that pipe.
I forgot to add that the reason I suggested JB weld is I used it on my fluxcore welding nozzles to protect the cups and tips. The radiant heat was well over 1000 degrees and it held up pretty darn good.:doorag:
:thumbup: I wasn't sure what the temps would be out on the Hindle but I threw this out there so someone would maybe check into it more before they used it. Next question, would you use JBWeld or either of the two Permatex products as a thread locker?
I just looked up loctite and the blue threadlocker is good for -65° to 300°
...BTW, just a heads up, you may want to make a thorough examination of that hindle when you install it. As you read (the reason for this thread) I bought mine "used" from a member of this site and was told it was only on his bike for a month. By the time I recognized just how bad of shape it was in the previous owner told me that it was my problem for trying to save a buck and that I was on my own...thankfully the rest of you were here to help me out...none the less my "used" hindle is going into the garbage when the new one arrives.(Thanks for the hook up Bone crusher:thumbup![]()
Hey lamonster, would that muffler seal work as a gasket for the hindle? Is that what you plan to use or some type of RTV? I will be doing another install soon.
almost 14k no loose rivets but paint is starting to show some wear.
Used permatext right from get go no problems :spyder:
copper silicone holds up to 700 degrees....don't think we get beyond that, do we?
...none the less my "used" hindle is going into the garbage when the new one arrives....
if you have the skills you may be able to rebuild it...it looks like the leak on the can may be the result of the can rivets coming loose? IDK
Anyway, if you can wait a week or so, I will pack and ship it express for $50 total to your door. I need to get the new one and find the time to do the swap.
PERMATEX® Muffler & Tailpipe Sealer Seals holes and leaks in mufflers, tailpipes and around joints. Makes new installations more secure. Resists temperatures to 2000°F (1000ÞC).
Suggested Applications:
Mufflers, tailpipes, joints and catalytic converters.
Prod 80335
I could not get the permatex sealer to work for me. Blew it out in one day. Tried some different stuff that looked like the same thing as the permatex. The only difference I could see was the instructions on how to apply. The permatex said to wet surface before applying and the other did not. That didn't work much better, blew that out in about a week. I still have my leak, when I take the Spyder in for brake replacement I'm going to have the tech fix it.
