I recently came to change the rear tire which was the original - on from build date July 2014. I removed the rear wheel myself using the rear shock method following the online videos. I got stuck when I tried to remove the shaft as it wouldn't budge. All the videos show it coming out easily but I had to hammer mine out. When I eventually got it out it was rusted up and dry as a bone where the bearings sit.
So if you'll pardon the expression - check your shaft and get it greased up if needed!! Might remove the problem.
For reference mine had not had the rear wheel removed from the factory and I bought it 6 months old complete with the whine. Also the whine has been consistent in my ownership up until new tire and now it's completely gone.
You referenced a video you used as a guide. Do you have a link to that video? Thanks
The position looks pretty much bang on to me, but what is it that rubs on the outside of your belt?As promised. My whine is gone for the most part. It was more of a whistle. My belt tension was about 110 (low) and my belt was 3.2 mm from the inner rim of the sprocket measured with a digital caliper. My new belt tension is roughly 150 and the distance from the inner sprocket rim has been adjusted to 1mm (too narrow to measure with a caliper).
I don't have this problem as I have an older 998 RT so this is just a shot in the dark but is it possible that a squirt of belt dressing would remove the whine?:dontknow: Just extrapolating here from the dab of grease results. Hope you all find a cure. We went thru this with Yamaha on the Royal Stars and they finally came up with a clutch basket change out, but if that didn't fix it you were just SOL.View attachment 174624 The wifes 16 F3T just had the front sprocket replaced with a new one after she complained of a whining noise under load/acceleration. The shop said the splines were wore and replaced the sprocket under warranty. Since then there has still been a whine/whirrring sound, but the belt alignment looks good, other than the front sprocket which is running towards the outer edge.
I thought that the belt might be getting "used to" the new front sprocket but last week when I was laying under it I used a pea sized dab of synthetic grease (Harbor Freight gray tube) and with it on the end of my index finger, spun the belt and applied a slight amount to the crest of the belt teeth and a little on the outer edge which was close to the front sprocket flange.
Since then, my wife says the noise is gone, and all is well with the world... hoping so, Your results may Vary:dontknow:View attachment 174625
To answer your question, no.
I think you're right in assuming it's the belt.
Better get used to the noise. I had the same noise issue on my 2019 F 3 basic, the machine was in the shop for 7 weeks, the shop was in constant contact with BRP engineering and performed many recommendations from BRP without success.
The final outcome was an agreement between the dealer and BRP to replace my unit with a new one, however the new unit makes the same noise.
Never thought of that. Great idea. I will try it!
Synthetic grease won't cause the belt to deteriorate? That would be my concern. I was considering doing the same thing to mine, using Mobil 1 grease.
