High beam Wire Location
Drwerner
I installed a set of driving lights that I want to come on with the high beams via a relay - anyone know where I can pick up the high beam wire? Thanks!
Find the wire that energizes the high beam shutter and tap into that. I did that on my 2011 RTS, worked fine.
It's been several years since I did it and I have sold the unit, so here's an idea. If you remove the Tupperware that gives you access to change the headlight bulbs, you will see the shutter. Just tap a wire right at the shutter. If recall correctly, it is on the right side.
