Outkazt RS-S
Hey everyone,
Got a little issue with my new aftermarket HID kit I just put into my 2011 RS-S. Got a Bi-Xenon H7 Kit and got it all installed. The way my kit said to install it was with a provided relay to power the ballasts. I wired the relay directly to the battery as it said and it uses one of the OEM head lamp connectors to activate the relay which means the other OEM headlight connector is not attached to anything. VERY intermittantly, I am getting a VSS Fault on my cluster and the bike will start and stall. If I cycle the key a couple times, it will start. It doesnt happen often enough to really pin it down. I emailed the supplier of the HID kit to see if I actually need the relay for the Bi-Xenons. My gut tells me that I should be able to use the OEM headlamp connectors to input the ballasts without any issue, but I dont know if its special because of the dual beam. My other thought was that my ballasts may be inducing voltage into the VSS module. I have the ballasts located on each side of the air box. Anyone have any thoughts? Thanks in advance
J
J
