Hey Ya'll We Got A New Member! Lets welcome Aligon to SL
SpyderBOT
Welcome Aligon, post up a hello, introduce yourself & get that 1st post notch on your Spyder!
Thanks for joining our forum community Aligon, from the staff at Can-Am Spyder & Ryker Three Wheel Motorcycles.
Here's some helpful links to start you along your journey here @SL:
Forum Rules and Guidelines
Do's & Don'ts for new Spyder Owners
Check out & add your Spyder to the Garage
Check the Visited Maps page & add your traveled Map to your signature
Do NOT post support questions here, please post them in the appropriate forum once your account is approved.
Charging issues
I need help. 2013 rt limited. Has battery charging issues. I put in new battery. Same problem. I put on a new regulator rectifier. Same problem. Now I’m stuck on what to do next. New battery new rectifier before I order a new stater. Does anyone know or have had this problem before. Any advice would be greatly appreciated.
Welcome to the forum Aligon. I hope you enjoy it. You can find lots of good information here on the Spyder RTL in the different areas of the forum. You should repost your question in the Spyder RT Touring area of the forum when you are able to so other member can reply and help you with your problem. Also post a photo of your Spyder in the Spyder Garage area of the forum when you are able to if you like for others to see. Once you have been processed into all the systems here at SpyderLovers you will be able to post in all areas of the forum and use the search function to search older post for problems that you may have now. I hope to see you around the forum soon. :2thumbs:
