helppppppp kewlmetal filter removal
NVERLAST1
Can someone tell me the steps to remove filter? I removed the top bolt but the top not coming off. What am I missing? Or has the heat made it stick?
Let's see....
Kewlmetal system is the same as the JT's. You have a top nut then a top plate...the filter and the bottom plate. Typically removing the top nut should allow you to remove the top plate. It may be stuck wiggle it side to side up and down and see if it comes loose. Some times they put an o-ring in there that may now be like glue. That threaded bolt also threads into the bottom plate so if the top plate is really stuck you can spin it and get it loose enough to remove to hear filter. You may not clear to hehe backbone (top of the hehe frame). Hope it's just a little stuck....:thumbup:
