Was replacing the headlight bulbs on 2010 RS the I dropped the retainer that holds the bulb to the socket which it turns out you need to secure it to the lamp fixture. Got the other one put in but took it out to see if I could find a match and dropped that one in the nether world of the engine as well. Dealer doesn't show the part, BRP couldn't help Hella didn't call back so I started removing body panels. Trike is completely apart in the garage and still can't find them. The weather is finally starting to turn here in Minnesota and I can't ride. Any suggestions would be appreciated. Would replacement LED lights work?
Thanks,
Barry
Thanks,
Barry
