Help with trunk issue.
Buggy
I got around to installing Tric led 3rd and 4th brake lights....five hours later and more adventures in Spyder disassembly then I expected I am much more familiar with Spyder construction then I expected to be. I will save you the details but my trunk will now not lock. I took the rear trunk panel off again a number of times but the lid does not engage the latches.
All the screws are in and the panel looks to fit perfectly but I must be missing something.
I am going to give it a go again tomorrow. Anyone else ever deal with this problem?
Search here on SL as there have been others who've experienced the same problem. As I understand there are pins or some such devices on the body panels that while appearing properly installed are not quite so and they keep the trunk from locking.
Common problem
Remove panel, 8 screws. Flip over. Top center, find a small tab. See slot in back where tab goes. Replace panel, making certain tab goes in slot.
Yup! :agree: That little tab has to engage properly... Everything will bolt back together, but the latch won't engage... :shocked:
I've been bitten by this one TWICE! :opps:
I had the same issue and cptjam has nailed the solution. The trunk reassembly can look correct but unless the tab is where it's supposed to be the trunk won't latch.
TRUNK LOCKING ISSUE
....I had the same problem and fixed mine without a complete dis-assembly, loosen the latch bolts slightly and then close the trunk.....the catches may be able to align the latch......it did on mine ........Mike :thumbup:
Found tab....inserted tab....problem solved with thanks to all!
I am no longer a Tupperware virgin having had to remove the rear panel, lower black panel and left taillight assembly to complete the install. Feels good to have tackled that demon:clap:
Same way
I also had to do it the same way you did. Just tool a little while to figure it out . goat232
:congrats: :clap: :2thumbs:
WOW !!!
THIS IS WHY I LOVE THIS FORUM SO MUCH IN SUCH A SHORT PERIOD OF TIME
Before I pulled the back panels off again after installing my TriLED light kits, I googled "rt trunk won't latch" and found this thread about the tab upon re-installation of the painted back panel across the back. Made the adjustment and poof...trunk closed and latched again.
boy, I'm still not sure how to install that panel without breaking off the forward tabs that key to the top inside of the side bags with the passenger grab handle in the way. I found them broken and glued them back on with some Loctite plastic glue, but they still couldn't bend enough to slip in their slots undamaged.
miracles of miracles after all that work, I still had the exact number of bolts and hardware to put back without extras.
woo hoo...let's ride
:shocked: That's the only part of the process that terrifies me... :yikes:
It's almost as if you need about six hands, to bend everything is fourteen different directions at once!
Rear upper panel
No tricks; remove 8 screws. Use a soft item (a Popsicle stick works) to make sure the dirt has not glued the panel in place anywhere. Use the stick a couple inches above the passenger hand holds, and bow the panel out enough to get your hand on it. Use the other hand to protect the lower tabs as you lift. Gets easier with practice! Joe
