daveinva
Just installed ESI's Triple Play and the center taillight. Have a couple of questions/problems:
1. What does the item with the lone plug (in the far left of the image) included in the Triple Play kit do? I didn't see it on the instructions, and have no idea what to do with it.
2. Without installing that part, the Triple Play works fine as a steady-on device... but switching the unifier switch back and forth doesn't appear to change anything, EXCEPT one time, I *did* get the flashing turn signals with braking action. Once I had it running, I was happy, I stowed all the wires away and put the bolts back in. Turned on the Spyder again, and no flashing lights-- just the steady-state brake lights again.
Is it because I'm missing that piece from #1? Is it because I have a lose wire? Is it because I have a bad unifier? Is it because my Spyder's haunted???
3. For the life of me there was no way that size heat tubing was getting on the turn signal LED wires. Is it essential for that tubing to be on there? How much heat do those wires get exposed to anyway? Or is that my problem in #2-- without more insulation, the signals don't flash?
Appreciate the help... love the product, even if it's just steady-on (those signals are BRIGHT, and love the center taillight, too). But it'd be nice to have it fully-functional.
