Help with headlight bulb
MrBones
My 2010 RSS SE5 headlight bulb went out. Is this a bulb I can get from an auto supply store or is it another CanAm only? All the specs say is that its a 55 watt bulb. From the picture in the manual it looks like a small version of a car bulb. On my other bikes they gave a H4 H3 type of bulb. Do I have to go to a dealer or is there a better place? Also is there a trick that you can share as to the way to replace it? Thanks for any info you can give.
SPYDER BULB
You can get them at any auto parts store......I don't remember exactly what bulb you need, but it should be listed in your manual as to the type........you can get a Phillips + bulb ( halogen bright white ).........Mike :thumbup:
Agree..!!
:agree: I believe yours are the H7 and are available in many tyoes. I am using the bight whites and they do well....:thumbup:
Rss bulbs
Remove windshield. Remove safety card. Remove dash cluster; unplug. Reach in, quarter turn, remove bulb. Unplug. Go to auto parts store. Replace. I thought it was a hb3, but been a while. I forget. Like 8 bucks, vs 20 at dealer. Plug in, insert, replace dash, replace windshield. Done!
call me if you get stuck; but I am in Alaska: time difference. Joe
