NOTE: When fuse 6 is installed, 12 V power outlet is only operational when ignition switch is at ON position. When fuse 7 is installed, 12 V power outlet is always operational.
I get my 2017 RT-S today and want to make sure I get the correct fuse changed so I can charge my battery using the outlet in the trunk. It seems this fuse movement is different than on my 2014 RT-L. I copied the above from the 2017 manual. So, do I move #6 over to #7? Thanks.
:spyder2:
:spyder2:
