Help with Bushing
zip3151
Any help......2014 Rt. Just move it today to start it.
Found this on the floor after I push it back to start.
It came from the floor brake side. I have not had the panels off.
Thanks3894C9A0-004B-4D34-87FC-9F9846F45EB5.jpgD3C52DC0-28B8-4570-B9D3-B8D3075D4154.jpg
It looks like one of the several grommets that help secure the plastic body panels. Has a dealership had the panels off? It could have been pushed out and been hitching a ride somewhere in the Spyder for a good while. Check to see if one is missing and if there are none missing it may have been riding along ever since the Spyder left the factory. I worked test/quality control at a factory that built large trucks and you would amazed at the stuff I found in or on finished trucks. Half of my fancy tools came to me down the assembly line. :ohyea:
Those rubber grommets are pretty much all the same all over your bike. I bet yours came from the side panel where the fake trox bolts are. The ones down by your knees as you sit on the bike. Pushing the panels on can dislodge the rubber causing them to fall out. And then they finally find a way to the floor eventually
Grommet
A zip tie will keep you from losing them if they are pushed out when installing the tupperware panels.
