Help - want to change dash light color?
You did it Bob... now what he can do in Spain with that information is a whole different deal. :2thumbs: Thanks, and JJ said to thank you all he will work on his English... ;)
You did it Bob..now what he can do in Spain with that information is a whole different deal. :2thumbs: Thanks, and JJ said to thank you all he will work on his English..;)
Hola de nuevo Chupaca.
Dile a los compañeros que ya se como se cambian los leds interiores del cuadro del cuenta Kms.
Aun no lo he echo pero en cuanto lo tenga os pondré las fotos por aquí ¿ok?.
Salu2 y gracias por todo.
JJ.
JJ38 says thanks for all the help. He has found a way to change the led's and will post pictures of the completed job... Glad we could help... :thumbup:
JJ38, si pudimos ayudarte fue un gusto y un placer... Felizidades... :ohyea:
JJ38, si pudimos ayudarte fue un gusto y un placer... Felizidades..,:ohyea:
Aqui os dejo la fase del cuenta Kms desmontado y señalo los leds que hay que cambiar.........quien se atreva jejeje.
Ahora os dejo un mod,espero que os guste.
JJ38.
JJ38 has posted pictures of the process to change your dash led's. He says this is how if you dare... :roflblack: check it out above... :thumbup:
I'm too chicken
; but would you please thank him for us? :2thumbs::clap:
Chupaca,diles que el trabajo no es muy dificil,solo hay que comprar 4 leds AA4040 y que los cambien en algun sitio que arreglen aparatos electronicos y no hay ningun problema.
El desmontar el cuadro del cuenta Kms o Millas es very easy jejeje.
Si necesitais mas información no dudes en pedirmela.
Thanks to all.
​JJ38.
Thanks to all.
​JJ38.
JJ38 said to let you know the mod is not that hard to do. You will need to buy 4LED's aa4040 and take them to an electronic repair shop to replace them. Removing the panel is very easy. If you need more info don't hesitate to ask... thanks to all.
