Thank you all for the replies. Sorry I haven't posted. Work is busy.
There was an audible "POP" when I turned the key originally.
I blew out the ignition switch with canned air. I checked all the fuses None are blown. The battery should be fine and the connections are solid.
Still nothing happens when I turn the key.
How do I check the relays? Or do I just replace them all. Is there a ""master fuse" that is not in the fuseboxes?
I'm thinking that it may be the ignition switch itself. The "Pop" did not sound like it came from the front.
I know if I have it towed into the dealer and have them repair the trike, it will be very expensive. How hard would it be for me to replace the ignition switch? Seems like it should be easy. Should I just try that and the relays, then submit to the Dealer's abuse? (relays would be first)
Thank you all for your thoughts and suggestions.
Ron
Ron
