Yazz
MOgang Member
How did you wire up the Garmin?
Was it direct to the batery or is it hooked up to a switched circuit?
If it's direct to the battery, you have to make sure you either remove the Garmin or turn it off before you leave the Spyder. If you don't the Garmin will remain on and drain the battery.
If it's a switched connection, it will disconnect when you turn off the key and the problem lies elsewhere, maybe a shorted wire.
Just my opinion, I could be wrong.
The Garmin is hooked straight to the battery thru a fuse. Had the Garmin hooked up to Spydee once before this debacle.
Understand totally what you are saying. The same thing holds true with electric underwear wired to the battery.
Think the battery was getting ready to kick the bucket and the Garmin was too much for it.
