Help Please !!!!!!!!!!
tea6638
Took mine out for a little ride today and noticed a side to side travel in the front end while riding at 45mph. Almost like wind turbulence but, there wasn't any. Just buffeting from side to side. Anyone else experience this or was just me. going to take it out again tomorrow and see what happens.:dontknow:
Was the road rough, grooved, heavy, crowned? And are you sure it was the front and not the rear. Sometimes on rough roads you'll get a little waging from the rear, especially if your holding the handle bars real tight.
I was just thinking that, Bersquack. It just might that my grip was too tight. I've never ridin a Spyder before and I know it will take some time to adjust. Thanks for the input.:thumbup:
With time you will find that a light grip on the bars works much better, especially since you actually feel more of the road with the two wheels up front. Depending on your size, you may also want to increase the setting on the front shocks and the pressure in the rear shock. Many of the RT owners have had to do this in order to stiffen up the ride.
:congrats: on your new Spyder, stay safe out there.
Check your tire pressure, I keep mine 18 to 20 in the front, 26 to 30 in the rear, lower than that, it gets squishy.
john
Light grip ------sure, that helps, but it's most likely the tire pressure as retread said. Also put your shocks on the highest preload.
I've got the same problem, ALWAYS feels like it's being buffeted by the wind.
One of the reasons is---IT IS. It's a snowmobile on the road with a huge barn door front end.
I increased my tire pressure to 22 PSI in the front, 29 in the rear. Maximum air pressure in the rear shock and maximum preload on the front shocks. That helps alot, but I'm not 100% pleased.
I had an opportunity to ride a pre-production model RT recently. A much stiffer ride. Tracked like it was on rails. The dealer is contacting BRP to see how the pre-production model is different from the one I own. We might try putting some snowmobile springs on the front.
As always, my free advice comes with a double our money back guarantee.
Thanks again guys. I did take it again today, pumped up the rear and eased off on my grip, it was a little better. I think I'm going to try what Lamont did, other shocks, I think he said RT shocks ( Not RTS shocks).
No, Lamont put the RT (RTS) shocks on his RS, and put Elkas on his RTS.
Talked to my dealer today to try and resolve the difference between my RT and the pre-production demo that he has. Both of us have agreed that the pre-production unit tracks much better. He spoke to the BRP tech guru and the concensus is that I may have a bad alignment. I'll take it in Thursday night to have them work on it Friday. I'll post more later.
On a second point, the gas gauge, my new gauge is as steady as a rock.............. but it's wrong. So is the pre-production model. The dealer is going to play with his demo and see how much adjustment the float needs to make the gauge more accurate. The low fuel light should go on after burning 5 gallons of gas. That will leave 1 gallon in the tank. There is about 0.6 gallons that is left inaccessible for expansion.
Let us know how you make out. MY RTS wanders around like a four year old playing in the yard, too. The only adjustment available is toe-in, however. Not much your dealer can play with here. I know that mine is bad enough that I avoid certain conditions, like today when I had to hit the highway in the wind. I rode my BMW instead. Even at a 30 degree angle it was more steady. Two-up is bad, too. I regretted taking my wife for a ride yesterday.
As to the gas sending unit, it will be interesting to see if they come up with a fix. We all could benefit. I'me sending my expensive gas gauge to the trash, but the accuracy is still a problem with the digital meter.
Here is the latest. Understanding , of course that I am offering a double your money back guarantee on my free advice. I offer the following tongue in cheek.
For those of us who have been "Dancing with the RT"................
You do NOT have to get used to the ride
You do NOT have to understand that it's not a motorcycle
You do NOT have to get 2000 miles of seat time
You do NOT have to be on the very top of your game through all turns.
You do NOT have to get accustomed to the unusual behavior of a three wheeled vehicle
You do NOT have to grow accustomed to the unusual side to side buffeting of the RT.
You DO have to get............................................an alignment.
My Bike had 1/8" toe out on each of the wheels. That's 1/4" over the whole front end. Toe Out is what makes the front end hunt and peck and feel like it's wandering around on it's own.
Obviously the RT is in its own category, and those that offered the above advice are wholly correct in regards to steering and breaking behavior.
My real point is, if you feel that your RT is wandering across the road, get it checked out. There may very well be a fix.
IMHO, this also explains why not everyone has been complaining about the dancing RT. Not everyone has the toe out problem.
:thumbup::thumbup::thumbup: Thanks for the update. Excessive toe-out has been my suspicion. We'll see if a couple of us also have the same problem. Glad you got your dealer educated.
I'm not sure how we got onto this topic, but talk about an alignment correction................Here is mine.............................
I thought I had a toe-out problem with my 2009 SM5. I couldn't find anyone to check/fix it, though. Dealer in Pittsburgh said that you have to have a Laser alignment system and most dealers don't have these.
I just hope my 2010 RT doesn't have the same problem.
