Lone Spyder Ryder
:helpsmilie:Hi everone,
Do any of you have a picture of the R35 Saddlebag Brackets installed. A close up perfred if possibe. I am searched all the forums but unless I just missed it there are none of just the brackets install with no bags. The directions just don't cut it for me. but then I most always need all the help I can get.
thanks.
If you have pictures you can just email them if you feel like it.
[email protected]
thanks.
Leo
P.S. This may sound crazy but in the instructions don't make much sense. page 4/10 says 1. on the RH rack reinforcement install rubber gromment to the muffler bracket. shows picture. 2. locate the upper frame bracket where the passenger foot peg support is attached. 3. remove screws ect. 4. align the reinforcement upper mounting holes and the front support mounting holes with the holes in the upper frame bracket.
5. thread provided M8X30 screws to the hold reinforcement adn front support in place but do not tighten yet. then the picture shows the battery. I thought we were on the right side. which side are they talking about? 1. says we are working on the RH side and 5 is showing a picture of the left side. which side is which. the muffler which they are talking about in 1. on the RH rack reinforcement install rubber gromment to the muffler bracket (which to me is the right side of the spyder. 5. they have switched to the left side.
Am I nuts or did they switch side mid-stream.
thanks.
[email protected]
thanks.
Leo
