HELP NO AM Radio and FM
J48cruiser
I have lost my AM on my radio what is there is LW and MW and on FM the numbers do not match what we have. My Ride is a 2015 RT Limited with factory Xm witch works Fine. the bike has not bin use since November just started it today and had this problem. Any Help would be great.
It sounds like the battery may be low since you mentioned it has been idle since November. When funny electronic stuff happens, that is sometimes a clue.
Your Radio / Dash may have switched regions since you're seeing other country radio settings. Check your manual Page 35, ,it's in there.
"Selecting the Region (Audio)
To select the region:
Select AUDIO in main category of Preferences Screen.
Select REGION in secondary category.
Select the appropriate region according to the table below in main unit or
setting.
NOTE: If your country is not listed in
the table below, select a region with an
identical frequency range.
Restart the vehicle in order for changes
to take effect.
Should be :A: for North America
