KYRider
Could use some help with grips:
Any suggestions would be most welcomed. Thanks in Advance.
- I have a 2016 F3-T
- I like ISO Grips and wanted to install them on my F3. J&P Cycles says they will fit a 2016 F3-T
- Ordered the grips, looked like the right length and 7/8 diameter.
- I cut off the left hand grip. Then notice it is on a sleeve held on by two screws.
- Saw "no-way" to get to to fit without excessive trimming of the sleeve and still unsure I could get it to work. Decided to stop right there.
- Called J&P Cycles and returned the grips (they are great on returns and customer service)
- Took the grip I sliced off and put it back on temporarily with gorilla tape.
- Can I just replace the grips with any 7/8 diameter grip of the same length or do I have to get a specific Can Am OEM grip?
- Is the throttle side also 7/8?
- I am assuming from posts I have read here that that is the diameter.
