HELP LEAKING ANTIFREEZE
Make that two of us. There was a bit of discussion about this in a few very long gasoline octane posts and I thought the concensus was that the Spyder did not have a knock sensor.
I will look thru the manual tonite when I get home.
If the Spyder does have a knock sensor why wasn't it covered under warranty:dontknow:
Either way, it sounds like you have yourself a stealership and need to find a dealership. Good Luck. Ryde Safe and Enjoy:thumbup:
sabunim5:spyder:
I have a FREE appt to get the part put in on the 22nd, I will then post what it is with part number, and yes you guys are right, I do have a stealership on my hands. Wont be using them for my 3k mile svce for sure.
Have it goin on right now small puddling on floor cap is ok only dripping when cold at dealer now being pressure tested :spyder:
UPDATE several odeker clamps (hose clamps) not crimped right at factory and had to be tweeked up hence while only dripping when cold :spyder:
Glad you were able to find the problem and cure it.
-Scotty
Hopefully that is it for a while I experience a rash of dealer visits toward the end of ridin season but everthing seemed to be real tite today happy again in CT.Hpoefully I could get a couple more hundred on her before the Snow starts fallin here.Don't realey put anything away until until the sand and salt hits :2thumbs:
Hello guys !!
I also found some coolant on the floor and after taking off
all the right hand side panels I didscovered that the leak
comes from the water pump housing. I checked the tightness
of bolts and the one that is next to the leak was not fully tight.
any one has had the same experience ???Thanks.
Yes, mine just started leaking and sure enough the clamp bolt was not tight at all! Everyone should take a minute and check their clamp. It just might prevent a problem down the road.
Hey!!! That's the clamp that was leaking on mine! :joke::D
This mean you're out riding Rando? dltang and I both rode to work today. :2thumbs:
I noticed the leak from it just sitting in the garage with the occasional start up during the winter months to make sure it would still run. I took it for a 2 mile ride today after fixing the clamp and adding some antifreeze that had leaked out. It won't be long now and I will be using it to commute to work!
