SPYD3R
HELP!!!
I need an Electrical Engineer, or somebody knowledgeable on 'battery drain' issues... :gaah:
Got home from Utah with ZERO issues; next day, DEAD BATTERY (NEW in Jan. '13)! I put it on charge - motor started; next day - dead battery! Charged it, repeat; repeat; & repeat... :banghead:
I removed the NEGATIVE wire from the battery and put a meter between the battery and the NEGATIVE wire... unplugged everything I've added, system is still pulling 12+ V.... I disconnected every OEM electrical connection I can reach, one at a time, and I checked the meter - 12V was being pulled every time! Most of the Tupperware has been removed (see pix) to access the variation of electrical connections. Has anyone else had this issue?? I would appreciate any help at all.
