Installed a double USB outlet in place of the blank in the center between the other rocker switches. Tapped the + & - wires that run to the temperature guage. Ran the wires from behind the RT. Side mirror the up to the underside of the rocker switch panel. Check the power by holding the leads to the posts n the back of the USB all was good. Fished the wires up through the hole, attached the ends, & connected to the posts on the back of the USB outlet. Buttoned things up. Turned on the ignition, no power to the switch and none of the dash powers up. Lights work, engine runs, but no turn signals, and other things don,t work. Fuses appear to be good.
After much head scratching we think that we may have shorted the wires before the bike actually shut down after we turned the ignition switch off.
Hope we didn’t mess things up to much.
Any help in trying to solve this issue would be welcome
It was a blown fuse all is good now. Thanks for the assist
