I was going to ride the spyder to work this morning, but when I turned the key on, there was absolutely nothing... no display or anything. The only thing I can think that may be the cause is just before I rode it two days ago I unplugged the two gauges to get the more accurate bar graphs on the display. I just left the wire plugs hanging behind the dash so I'm wondering if battery power got shorted to ground thereby draining the battery. I didn't even take time to check battery voltage as I had to take another vehicle and get to work. I don't see how either one of the gauge harness could short the battery as there would be no power to them when the ignition is off. I rode it for half an hour after unplugging them with no problems. Anyone had this happpen or have a suggestion? It's only got 3500 miles on the clock. I guess it could be completely different issue that just coincides with the gauges being unplugged.
Russ
Russ
