Help! A plastic bag melted to my exhaust.
librathe13th
While riding last week I notice a white plastic bag blow from under the car in front of me and before I could react it went under my spyder. When I got home I saw it had melted to my exhaust connection pipes. It is a real eye sore. Any advise how to remove with out causing any more damage? I heard something about easy off oven cleaner ?!?!
Multiple postings... :shocked:
Please put your question or problem in one place; it'll make it easier for you to keep track of the responses!
Thanks! :thumbup:
Did it melt to the pipes or muffler? If it melted to the pipes use a heat gun on high and work slowly heating it up and quickly wiping it off. If on the muffler painted area that's a tougher job but the same procedure will work just be careful of the heat on the paint.
Let's see..!!
about all you can do is wire brush all you can then start it up and heat whats left and brush some more...oven cleaner is really not a good idea unless your pulling the pipes apart...:dontknow:
