Heated grip on off button size
Mr Safety
I am looking to take advantage of the other button position opposite of the one for the heated grips to have my LED lighting on. But I'd like to use the same size and type of button (switch) that is used for the heated grips. Anyone have an idea of the size or a place to purchase ?
This is what I used for the same thing. 19mm Metal MOMENTARY Push Button 12v Switch Green LED Angel Eye Waterproof( 281359409065 ). $7.50 off ebay. I use one for the fog lights I put in and one for my led lighting.
CJJAX
.......If it's MOMENTARY .....then you have to keep your finger pressed down to make this work constantly .....is this what you do ??????................... Mike :thumbup:
Thanks for the catch on that one. I grabbed the wrong link. I mounted the momentary switch to operated my garage door controller. It is located on the left side of the bike below the seat in the seat pan knockouts (#23) and the switch for my led's is on the right. I wanted to keep the stock locations for my foglights and heated grips (which I haven't gotten to yet). The actual switch I used for the led's was a Waterproof 19mm 5A / 12V Metal Flat Red LED Light Push Button Switch Latching( 261676911803 )
