Do the 2014 ST's have any Heat issues like the 2013"s?
Rich
I have a new 2014 ST and the heat on the right side is horrible. I had an Fan Can on my 09 RS but have been told it won't work on the ST. Does anyone have any suggestions for the heat coming out of the right side. I have highway pegs that are a bit longer than standard and even in boots, socks and jeans I can't stand the heat.
Help/Suggestions will be appreciated.
Sorry to say, the OP was referring to Spyder ST not RT.
The 2014 ST is nearly identical to the 13 except for 4 body panels that were replaced. The 2013s have already been updated for those and the ECM updates. At this point, 2013 thru 2015 Spyder ST are functionally identical.
I can symtethise but your two options are to trade it in for an RT or F3 or mod the bike to direct the heat away from your foot/leg. While mine is an RT some of this is similar. We blocked the right side radiator discharge vents entirely, removed the lower underbody covers and revised the duct behind the radiator to direct the heat down at the road rather than out the side. For us, it solved the hot foot problem entirely.
I see references to updates and new panels, are those something BRP covers or is the owner responsible for the cost of those things?I have a 2013 and used to have a lot of heat right in front of the seat and on the sides.
Since getting all the updates and the new panels. I have no heat issues anymore.
I was out for about 50 miles today. (In Minnesota) We don't get to do that much in March here!!
Do they make a fan can for the ST?I have ordered the Fan Cam from ISCI. CaptJim, wish I had seen the information about the difference in the panels on the 14 ST and opening it up. Not an issue, tho because I have used the Fan Cam before and it is good.
Thank you all again for the assistance.
