Headlights to LED's?
Brettssunshine
Is there anyway to change the bulbs in the headlights of a 2009 RS SE5 to LED's by just changing the bulb? I ordered several hundreds of $$'s from Custom Dynamics and changed the turn signals, made my side reflectors into lights, etc., etc. but did nothing with the headlights.
Also, when I changed out the bulbs on my rear turn signals, there was a pack of wiring (load equalizer?) that you could install but if you did, your emergency flashers wouldn't work. I left it off. I guess this was ok to do?
This is my first motorcycle, so it's a slow learning process and a lot of the technical things are still confusing. :sour:
Look for a local Cycle Gear to check a version out in person, but yes you can. They come with a mini adapter harness, but not sure it contends with the high beam solenoid. It's a issue of room to fit for some headlight assemblies on some bikes, but the spyder has a tube shaped housing so it should be OK. A few brands out there of this, it's becoming popular. Real wattage cutter, nanny may have a fit with it seeing the power loss, she didn't like my LED brake lights, but is okay with the turn signals.
