HEADLIGHT
bmccaffrey
I have 13 rs left headlamp is out.
What do i need for a bulb and how to change and what needs to come off
THANKS IN ADVANCE :bowdown:
You may have to pull the old bulb out to see what model it is and then match at an auto store. Or check with Lamonster Garage or Reggie at Tricled for matching LED lights. LED headlights are the only way to go IMO.:2thumbs:
Depends....
The bulb should be an H7 if it is like the prior models but things changed in 13...best take it out and see.
On the RS you can get to it by removing the console / instrument panel ( keep bandaids on hand)
On mine I removed the air box and access is very easy removing the center panel. If it is the left I think you can get to it that way but the right side the air box is in the way...:thumbup:
Did a trial run pulled the instrument panel and took off rubber cap. Didn't pull the bulb waiting for replacement to get here.
$30.00 for a halogen bulb:yikes:
Yes it's the left side. Tried to get price on led from lamoster garage and tricled no answer at either
may switch if not to bad to get my big hands in there and if I can get price
