spyderryder53
My left LED headlight went out so I replaced the bulb and it still doesn't work. I tried 2 new bulbs, the right one works so I doubt it's a fuse any ideas?
Are you saying you replaced the burned out LED headlight with a replacement LED headlight or did you replace it with a halogen? If you replaced it with a LED bulb is it possible you got the polarity reversed? Try a halogen in the right and if it works you got the LED polarity reversed.
swap with Rh side test all bulbs on known working side. Label/mark bulbs somehow help keep yourself organized. Inspect if spade blades are tight & same size, if had any trouble putting led in may have spread connections & vibrations eventually made worse. &or the blade went behind the connector not in. Happens all to often in tight spaces.:gaah:The plug has a lock together clip on only one side and its locked in so not sure how the polarity would be reversed. Maybe the burnt out bulb isn't bad and its another problem.
I replaced my Halogen bulbs on my RT with LED ones..fitted them the way they looked they should go and they didnt work... you can just turn the plugs around on the led bulbs as they can fit both ways. I pulled my plug out..turned them 180 degrees and refitted them ..bingo they work!.. So if its a bulb just try unplugging turn it around and replug it in..could be a polarity problem.
Ok. So i could use some help. 2015 F3S. Installed led headlights and they work fine until dusk when the headlights automatically adjust. They only work as high beams and wont turn off. 1 side actually went out. They are brand new bulbs. Didnt see a way to plug them in another way.
3 hrs out of town in need of help.
After checking my lights this morning, i realized that coincidentally my left light cut out as it was getting dark. I thought it was like my car. Daytime running lights and headlights when it gets dusk. I guess when the light went out, it became high beam only. Gonna take it apart after a lowes/ harbor freight trip and see how it goes before we head to Knoxville. Thanx guys.
