rtlister
I noticed today that the left headlight on my 2014 Spyder RT is out (bike is still under warranty) but they say warranty doesn't cover light. I flashed between high and low beam but neither high or low works on that light. That made me think perhaps it's not the bulb but something else...perhaps a loose connection (on a car bulb, usually one filament or the other, high or low beam goes out but not both at the same time).
So my questions are:
1. Is this bulb like a car light filament ...with high and low in the same bulb? Wouldn't it be rare for both to burn out at the same time?
2. If it is the bulb, how difficult is it to change (DIY?? ...the dealer charges $140 labor to change it)?
3. I've seen an add for LED with Lamonster ...recommend or not? ...and if you do recommend the LED, should I change both (including the one that is not burned out)?
4. A parts guy told me that the bulb is the same as an H9 65 watt bulb from auto parts store. Is that right?
5. Any recommended video (youtube, etc) out there on changing the bulb?
Thanks
Thanks
