AZ Desert Spyder
:helpsmilie:I need some advice from all the wizards out there. I installed HIDs in my headlights a few months ago, and it seemed that the headlights were aiming a bit lower than before. But it wasn't that bad so I never bothered to mess with them. But recently, I finally got annoyed enough that I got out a screwdriver to adjust them. I checked the manual to make sure I didn't mess anything up, and it seemed real straight-forward. Unfortunately, the manual doesn't say which direction (clockwise/counterclockwise) is up or down, so the headlights at first went down even more. So I turned in the opposite direction, but the headlights wouldn't go back up. Since I was getting ready to take the bike in for service anyway, I asked them to adjust the headlights. Now they tell me the plastic where the screws go in are stripped out and the entire unit has to be replaced! The cost with parts and labor comes to over $700.00!:yikes: I asked if my extended warranty would cover it and they said they would check. But today they called and said it's not covered because I live in Arizona and the heat will cause plastic to get brittle and break. Well, no sh$%^ Sherlock!!! :gaah: So if they know that, why didn't they make it with a metal insert? And I wonder...if I lived in a colder climate, does that mean they would cover it??? I'm obviously very disappointed with BRP right now, and I need some advice. The headlights are aimed so low now that it's not even safe to ride after dark, so I need to do something soon. Does anyone know how I might be able to repair this and avoid a $700 repair bill? I'm also curious if anyone else has had this issue.
Thanks for letting me get this off my chest and any suggestions would be appreciated.
