spyderwing
Morning, I am in the process of replacing a headlight bulb. Need your help/suggestions on how to get the new bulb installed. The manual said to turn counterclockwise to remove- could not get it to turn- finally got my finger on a tab inside the headlight tube to the outer or right side of the right light and pushed/pulled on the tab- it popped loose and was free with a little wiggling in a matter of seconds- I never did get it to turn ccw. It popped loose only after many attempts to loosen it by turning. Any thoughts now on how to get the new bulb reinstalled- it looks like it should be turned clockwise to get it in the permanent metal clamp/fastener at the front inside of the headlamp container-not having success! I have removed the gauge cluster and the upper side panels so I can get at it from the gauge area and from below but still limited room to maneuver. Appreciate any suggestions. Thank you. John
