Headlamp change
Yogie
What's involved in changing the left headlamp bulb on my 2014 RT S?
In other words.... What needs to come off the bike to get to it?
Either way the entire assembly has to come off.....................Mike :bbq:
I see what you mean. Goes to show I have never done an RT.
yogie Detailed instructions on page 152 and 153 of your owners manual. If you have questions after that there will be lots of folks that can answer specific questions.
REMOVEING PARTS
Does the whole nose need to come off?
I take it you mean the ...( NOSE ) = FRUNK .....NO.....just open the hood, you will see two bolts at the bottom of the panel that surrounds the lights.......take them out........First remove both side mirrors ( of course :roflblack: )....then the bolts that hold the panel ( torx ) after the panel is off ......you will see 4 - 10mm hex bolts, these hold the headlite units, be careful they get lost easy unless your sockets are magnetic.......the rest is self observant.....Mike :bbq:
