Head Light for RS
jtpollock
Help!! can anyone tell me the part number for the RS headlight and how to find the instruction on changing them out :banghead::banghead: I have looked over this sight and find a lot for RT's St's not RS's :dontknow: jtpollock
99.9 % sure
It's just an H-7 Halogen bulb that needs to be replaced.................PS it's NOT A DUAL filament bulb........GEt It anywhere cheap......Mike :thumbup::thumbup::thumbup:
It's just a standard h7 halogen bulb. Available anywhere auto bulbs are sold.
To Change it the access is behind the cluster and under the rubber caps on the back of each light. If you have really tiny and flexible hands it easy. If you have anything larger than twigs for fingers your either going to have to pull the upper console apart, or be prepared to lose some skin and say words you wouldn't normally say around kids.
Sent from my SCH-I545 using Tapatalk
H-7. .!!
any auto parts store will carry these bulds. Changing them is in the owners manual. Have to remove the instrument cluster to reach the sockets...:thumbup:
any auto parts store will carry these bulds. Changing them is in the owners manual. Have to remove the instrument cluster to reach the sockets...:thumbup:[thanks I checked the owner's guide but it's not clear are the releasing clips at a clock position like 10 and 2 I can not see inside the housing with my hand inside the cluster and I know how these clips are very easy to brake :dontknow:jtpollock]
O.K. :banghead::banghead:I got the bulb changed no one said to be careful not to drop the retainer clip it took an hour to find it as it stuck between the radiator and plastic bottom pan anyway what a bummer trying to get the bulb back in place but it's done :clap::clap: jtpollock
MINE
JUST FINISHED DOING MINE 20 MINITZ AGO....
WOW... NO EASY TASK I MITE ADD...
LISTEN TO MIKE (BLUEKNIGHT)... HE WALKED ME THRU MINE...
DAN P
EASLEY, SC
SPYD3R
